Repair and disassembly information for Logitech's H800 wireless headset. Supports 2.4GHz & Bluetooth. Released in 2011. Model number: 981-000337.
Micro-USB jack is broken
Ive recently broken the charging micro-usb jack on my h800 headset. At first i could charge if i put it in the right position making it impossible to use and charge the headset at the same time. Now it doesnt want to charge at all and i need to know if it is possible to get the jack replaced or just go buy a new headset.
Score 4
Add a comment
Most Helpful Answer
It's can be opened, but replacing the USB is not easy unless you have the correct tools.
Score 1
Add a comment
You have to use hot air gun and iron.
Look near you for some repairing center or just somewhere where smartphones are repaired.
It will cost something about 20$ I think.
Score 1
Add a comment
Add your answer
Matache David will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 29
All Time: 2,184
