The Huawei P8 Lite (Model: ALE-L21) announced April 2015, shows beauty in simplicity. Its professional cameras enable you to take natural and sharp pictures even in the darkest environment. The beauty mode highlights the best features of the owner in every selfie.
Huawei P8 Lite Problems with wi-fi
Hello,
I have a Huawei P8 Lite for less than 2 Months, before i didnt have any Problems with it.
But since yesterday my wi-fi doesnt work, when its connect to wifi it gots only 1 Mbps, i cant use any apps with internet like Instagram, Facebook but other devices works perfectly on my wifi like my laptop its connect without any problem.
I hope you can help,
Thank you
Score 110
108 Comments
I have this problem too :-(
Is there anything we can do to fix it.??
It's driving me crazy. My play store app will not let me update anything and if get an app that loads magicly it closes a minute later....
by
Hi,
Read on another site about a P8 not a P8 Lite. with Wifi problems, not connecting or slow when it did, so don't know if it relates to you but you can try. Check a setting in Settings > Wireless > Advanced > WiFi in StandBy select 'always' in the options list. I don't know if you even have this setting or if you do whether it will help but it shouldn't take long to check. If not there or it doesn't work sorry to have troubled you.
by
My wife's phone is doing same - P8 Lite - says 'access denied' on network. If clear the wifi details and re-enter same password very close to router it will connect, but then disconnect and not connect again if you move more than a metre or so away. Other devices all connect normally to our network, so the wireless router is all working fine.
There are multiple threads about this on Huawei's support forum, but nobody from Huawei has bothered to reply to any of them.
by
My problem is same ,wifi available but can't access.I reset my phone and try again but doen't work please help.
by
Me to but if I go to wifi my phone shows no wifi names.
by
Show 103 more comments
Add a comment
Chosen Solution
I found a simple solution and it worked.
Switch off your Huawei device.
Press both the volume down and the power button at once until the Huawei or Android logo comes up, then choose 'WIPE CACHE PARTITION'
Reboot your phone.
Wipe the cache partition again.
Reboot your phone.
Find the FM Player app on your device. Connect a headphone to your device (which is used as an antennae)
Play FM for a couple of seconds.
Remove the headphone and turn on your WIFI. It worked for me and I am sure it will for you!!!
@coolchasere
Score 21
29 Comments:
Connecting but with very low browsing rate...
by
Hi, I tried this option but still doesnt help
by
It works. Even without connecting to FM. Thanks.
by
When I press volume down and power Huawei logo appears and nothing more... where can I choose 'WIPE CACHE PARTITION' ? Please answer me
by
Its contenting but again after some time disconnecting, also IP address comes unavailable.
by
Show 24 more comments
Add a comment
Hello Guys, I've done deep search about p8 lite Wifi Problem, and it's not a settings you can change even if you format your device unfortunately.
the problem is that the antenna became weak for some reasons so it's a hardware that you have to change!
Score 13
3 Comments:
Hi
If this is the Hardware, why the 3G/4G is working while the wifi is out of order?
by
Dude there is tri baand microstrip patche antenna exists for wifi GSM and LTE WCDMA which works simultaneously.
by
i replaced the antenna module and the pronlem remains ...
by
Add a comment
Hi,
Change your IP setting to Static not DHCP. That worked for me. All you do is go to settings -> Wi-Fi -> Press and hold the network you want to connect to -> Modify network -> IP settings. Change it to Static and continue to fill in the IP addresses etc. And save. Works if you know your network settings
Score 10
7 Comments:
Your solution worked bro big ups
by
whare u put a IP
by
Cool. This worked in my mothers p8 lite as well...
by
thanks bro it worked
by
I can't access my ip address on wifi settings
by
Show 2 more comments
Add a comment
yes i have a solution of this problem ..
you will go in your wifi advance setting .....keep wifi on during sleep..
here is 3 options
1) always
2)only when plugged in
3) never
my friends you chose no. 3 (never) ......
Insha ALLAH your wifi keep alive and connected to net..
Score 6
2 Comments:
I've got always ticked and it still won't connect
by
AI Mos I did that it is still not picking up the open wifi
by
Add a comment
I found this on/off problem. Just if you use the CM security, there you have an option called lockApp on default this lock the WiFi, when you choose to not lock the WiFi, gone alright.
For me this worked.
Score 3
Add a comment
guys.. i scan in the phone manager ... n thw wifi is working now ;) try it
Score 3
6 Comments:
Yes, it was helpful! That's clear my phone cache, i think and Wi-Fi work properly now. It helps in Russia and i think it will help with any version of Huawei phone.
by
would you please explain how did you do that ?
by
Wht is that phone manager
by
CM phone manager scan is what killed my wifi, bluetooth and FM radio, it was working fine till I decided to do the scan
by
worked for me. thanks
by
Show 1 more comment
Add a comment
Solution (I don' know if temporary)
- Free space (internal memory was almost run out)
- Turn-off and then, on.
- Solved!
I don't know what relation could have between WiFi and internal storage.
Score 3
1 Comment:
huawei p8 lite wifi hotspot no warkey
Please help me
by
Add a comment
Go to wifi, click on menu, go to saved networks. Delete all.
Click on menu again, go to advanced settings, click on WPS connection and folliw the steps.
Hope this help, worked for us
Score 3
1 Comment:
Only Connected via WPS not with password, Again and again WPS it sucks pressing again and again
by
Add a comment
I found that the Developer Options were enabled , so I switched them off by going to Settings > Manage Apps > Settings (in 'All' tab) > Clear Data ... and it started working. I checked this by doing a restart and all was still ok. Hope it works for you.
Score 2
4 Comments:
Where can I find that developer option
by
To make developer option appear, go to About phone, see build number and tap it several times.
by
Omg... it worked xD !!!
by
I have made a developer, then after that?
by
Add a comment
Solution!
Go to the nearby Huawei Customer Services!! Get The Software changed!!
Score 2
Add a comment
-Turn off wifi
-Go to Settings, Apps and scroll down for the app Wifi Direct
-Turn off Wifi Direct
-Turn on wifi
Score 2
Add a comment
I think i have found the answer.
I was struggling with the same problem. Asked Huawei for an answer. They told me to make a backup and a factory reset.
I have android 6.0 on my P8 lite, backup & factory reset can be found under advanced settings. Here you will find the option 'network reset'. Use this option and the problem is gone :-D
Good luck to all.
Score 1
3 Comments:
Can you give us the solution step by step?
by
The probelm comes back later
by
I also have the Android 6.0 but nothing has changed, wifi doesn't get on
by
Add a comment
I had this problem for several days 'Network Access Denied' and tried all the fixers to no avail until I found a Wi-Fi update in my Notifications, applied this update and Wi-Fi scan could see many access points but still would not connect to my router. Pressed both the volume up and the power button at once until the Huawei or Android logo comes up, then choose 'WIPE CACHE PARTITION'. Powered back on and now its working. I am happy and the sun is shining. Hope this helps.
Score 1
1 Comment:
It doesn't work for me
by
Add a comment
Hey guys,
Try this simple fix, it worked for me.
Go to your "wifi settings". At the bottom right of the screen on the P8 lite there is a three line button. Hit that and go to "Advanced settings". Go to the option for wifi when asleep or whatever it is. Enable "ALWAYS" there and then reboot your phone.
For some reason this worked. I think it's an OS permission issue or something.
Add a comment
i have some problem before, you can test rollback transition your android OS, if not work you can install another firmware or flasing your huawei p8 lite. for firmware and how to install it you can go here huawei p8 lite firmware
Add a comment
Hello all
I had same problem danied access to network and then try everything about this wipe partition , clear data And reset factory all this solution didn't fix my mobile but I get the solution follow this steps :
Go to option
WiFi
Off your wifi
Click WiFi+ and on it
Then open WiFi and reconnect again
Will be connect inshaallah
With my regards
2 Comments:
Yes daniel
The problem come again after worked
But if i nearest from my router it connect
by
same with my phone connect only nearby
by
Add a comment
The answer was so simple, simply restart the phone.
Update (05/23/2017)
If you restart the phone and the Wifi does not work, then try backing up, earasing and reinstalling. If the hat does not work, call the helpline in your area for service center as the problem would be internal hardware. http://consumer.huawei.com/en/support/ho...
Add a comment
3.1 Download Android5.0 version upgrade package
http://download-c.huawei.com/download/do...
Copy the file named “UPDATE.APP” of Android 5.0 version to the folder named “dload”, and
the folder should be in the root directory.
Notes:delete the UPDATE.APP of the 1st update before this step.
3.2 Confirm upgrade package
Go into “File Manager”, then Local->SD card->dload, make sure UPDATE.APP is under dload
directory.
3.3 Rollback operation (same as chapter 2.3)
Follow this step to upgrade, power off, and then press the button volume+, volume-,and power at
the same time.
Add a comment
Hey guys,
I found out, that the Huawei P8 Lite seems to have problems with the 5Ghz from my Fritz!Box. As I activated 2.4 Ghz, the network showed up and I was able to connect to it.
Add a comment
Well, i have same problem with my GR5 2017, i can't connect to our office wifi. I thought the problem was my phone so I tried resetting it but still nothing happened. Then I tried asking help from an officemate and it turned out that my phone was put on a blacklist on the wifi setting. After he deleted my device on the blacklist, i can now connect to the wifi again.
Add a comment
Here is your answer:
https://consumer.huawei.com/pk/phones/ho...
Wi-Fi 802.11b/g/n, 2.4 GHz + BT4.1
Which means Huawei P8 Lite doesn't support 5GHz
Add a comment
Activate developer options. Switch off: use old DHCP client.
Add a comment
Download a Ram cleaner and use. Also make sure your Bluetooth is Off.
Add a comment
Easy hack. On your router setup, go to wifi settings, select advance, on the 2,4Ghz network select 20 MHz, sure it says 40 MHz right now, save the setting and apply. Now your wifi works on Huawei phone.
Add a comment
We have solutions to Bypass FRP Google Account from all Huawei devices check once:-Bypass Huawei FRP
Add a comment
turning off bluetooth increases wifi signal ! , clearing cache as above worked for me , cleared al lthe big stuff , google play , google , facebook , freed up 1gb and now wifi works . have also turned off developer stuff , and set
Add a comment
Switch off BLUETOOTH and download a RAM CLEANER. Did the trick for me.
Add a comment
All Huawei Models Frp Google Account Bypass You Can See Here Video Tutorials
https://www.faisalmobile.com/search/labe...
Add a comment
Add your answer
Qerim B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 92
All Time: 478,823
