Phone wont switch on
Hello have a phone problem ,it doesn't switch on the screen is black even after I changed batteries===
Hello geraldmtshali,
Hope above steps will help you to fix your BB
I removed my battery out of my phone, then when I put it back in again which was about 1 hour later it wouldn't turn back on, it has no LED flashing at all, I've tried plugging it into the charger and nothing happens and plugged it into the laptop that also done nothing. The laptop doesn't even realised I've plugged it in.
Can anyone help?
Hello shuvo, does BB manager detects your phone ?
no brother its not :(
Then it should be hardware fault. simply you can check the micro USB connector either it physically damaged.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 33
All Time: 6,043
We seem to be having the same problem, mine only flashes red when u try to put it on but yet remains blank
by normanchuma77
same problem
by Francis Gernet
My blackberry bold 9900 won't turn on I tried a new battery and it only worked for an hour or 2,then I charged the two batteries else where it also for an hour or two . when plug in the charger the led light turns red and u only see battery charging sign that's all.
by Kelvin
Same problem
by Robin Sauveur
Phon chargeing problam
by vijay chauhan
