How to clean dust from camera?
Hi guys!
I want to ask if it's possible to clean the dust from my phone's camera. I don't even know how it got dusty :( (if you need I'll post pics)
Hi guys!
use a sharp object like blade( insert it to the any edge of the round lens cover) to pull the lens cover (be careful with that) and blow the dust out (use ur mouth to blow) or a soft cloth
Well I'm a bit afraid of your method I think I'll just pass this :s
it is sooo simple and easy you just have to be steady are careful...
if you get the same phone i will demonstrate of for you with VIDEO
If you want clear the rear camera dust, you need remove the back cover. The first time the phone is disassembled, it needs some tools and operations.
This Sony Xperia Z1 Teardown can help you disassembly the Xperia Z1.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 15
All Time: 2,625
Maybe it is not the dust from camera but on the camera lens? No matter which one, if you want to clean the dust, you may need to remove the back cover firstly, and then use the soft cloth to clean dust.
by kristastic1990
