Battery operated Thomas the Tank Engine ride-on train with track.
Where to charge the train
Where do I charge the train, If I go under the seat which plug do I plug the charger to, so the train can work I have no idea what I am doing.
Add a comment
Chosen Solution
Apparently it's at the back of the train. The charger, hopefully you have it, is an unusual shape, and there shouldn't be any mistaking where it goes. Sorry I couldn't be more help
Score 2
1 Comment:
thanks a lot for your answer
by
Add a comment
You must remove the two Phillips screws on the black plastic seat. Remove the seat. Unplug the 2 prong hard plastic connector that goes to the 6volt battery. Connect the charger directly to the 2 prong connector that goes to the battery. Wait 6 hrs and then unplug the charger. Reconnect the connector that goes to the motor back to the battery. Replace the seat and tighten the 2 screws down. Enjoy!
Add a comment
Add your answer
Constance Briscoe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 58
All Time: 7,142
