The Trio Stealth G4, manufactured by Mach Speed Technologies, is a touch screen tablet with a 7.85” HD screen. The device has Wi-Fi, Bluetooth, and Google Play capabilities with features that include a quad core processor, and front and rear facing cameras.
Screen Cracked On The Tablet
Hi, I took my tablet to New York with me and didn't use it for the whole ride was going to though so I wouldn't be bored then on the next day, I open my case to my tablet to see that it was cracked. I did no physical damage to it. I thought the case was suppose to protect the tablet. Anyway, I have important information on it and I can't reset it because of the crack on my tablet. What should I do?
Score 1
Add a comment
Most Helpful Answer
What you need is a new digitizer screen for your tablet, while I have one here, I do not know how locall I am to you. I am in Michigan. Check a local company first for repairs. I charge twenty dollars for the screen and thirty dollars labor. Reach me at drslawinski2@gmail.com.
Score 1
1 Comment:
What do I type in for the correct search local parts and service
by
Add a comment
You can do what David Slawinski said and pay someone to repair it for you, but you can also repair it yourself for much cheaper :) This video will show you how
https://www.youtube.com/watch?v=ClSOlEdr...
You will need a heat gun or hairdryer the part is below it comes with all the other tools you need
For 7.85 inch: https://www.amazon.com/Atabletparts-Trio...
For 7 inch: https://www.amazon.com/Screen-Digitizer-...
An old credit card can be helpful for prying the old glass off. If you think you will want to repair stuff in the future I would suggest a toolkit, this is the one I have: https://www.amazon.com/dp/B00VJYWRKW?ref...
It is really nice, I fixit also makes some really good tool sets like this one: Essential Electronics Toolkit
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C). Image
Product
Heat Gun
$29.99
Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair. Image
Product
$29.95
Score 1
Add a comment
Add your answer
Stephane Caldwell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 995
