A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
When computer starts 4 beeps then nothing
I have a custom built computer with an Asus motherboard, and when I try to start it it beeps 4 times and then does nothing. The fans are running and the little green light is on the mother board but nothing else. Can anyone help?
ASUS M5A97 motherboard
AMD X6 FX-6300 cpu
G.SKILL Ripjaws 8GB ram
Corsair CS Modular CS650M power supply
ASUS GeForce GTX 750
Samsung 850 EVO 250GB ssd
3 Comments
is it 4 solid beeps or are there spaces2 long 2 short
by
4 beeps all the same
by
Replace the cmos battery. That sometimes gives 4 beeps if dead or it is your ram. Try change positions and use one stick when testing
by
Add a comment
Chosen Solution
Asus motherboards are usually American Megatrends' AMI BIOS. and if that's the case four beeps mean System Timer failure: Timer 1 on the mainboard does not work properly. This can mean that your motherboard has failed but before throwing it out there have been cases were the memory has failed on one dimm but not the other, so pull one dimm at a time and try to start it and see what happens
Hope this helps
Score 5
5 Comments:
I'll try this and let you know
by
one stick of ram didnt work the other did. its new just today so whats the deal. Thanks for the help looks
by
Found the A channel (a1 & a2) work fine, however, the B channel always issues the 4 beep System Timer Failure code on boot. Anyway to restore functionality? Or is this a permanent failed state?
by
johngonsalvesjr have you tried more than one dimm of ram or have you tried different dimm. it could be the stick or the slot so try different sticks . also remember that one slot is prioritized as first and unless it has a stick in it the second may not work . also just blowing the slot out may help as dust in the slot can cause problems
by
thank u guyss ur guide helped me even after 11 years. thou it was Zebronics motherboard but it has ami bios so I followed ur guide and it was really a ram causing the issue. love u guys. hope u all still alive and well....
by
Add a comment
Had same problem with a z77 board. Had 2 different sticks of ram and would get the 4 beeps on every stick and slot I tried. Plugged in a different psu and it booted?!
Add a comment
i got same problem i tryed with new hardware all switched even new motherboard, ram,processer,psu,gpu, i tryed it all..problem still there when i boot up. and it does not beep every time some times there is 2 or 4 days between i get these 4 beeps
Add a comment
i had similar issue, first just on and off, so then replaced battery, then 4 long beeps (gigabyt board)
turns out the ram sticks got loose, so it put them out and in well till the clasps clicked by themselves, and it booted
but needed to reset bios settings cuz of battery
btw, for a while i had strange issue where if i moved the cpu too much, like to get to a usb port in the back
then it blacked out till resetting it, seems the ram sticks were loose.
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 214
All Time: 74,965
