Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
Why is my laptop overheating?
Whenever my laptop is being used for a long period of time the bottom begins to get really hot. Is there any way that this can be fixed?
Score 1
Add a comment
This is a pretty vague, general question, since there are dozens of reasons why a laptop gets hot.
Through normal usage, though, the laptop internals (CPU, GPU, RAM, etc) will get hot from being used for a while. Whatever your system uses to regulate fan speed (if there is any active cooling inside) probably keeps your laptop operating at a set temperature deemed safe.
You may want to keep the ventilation holes free from any obstructions, like dust and other objects sitting in front of it. This will allow the heat building up inside to properly exhaust.
Add a comment
It truly depends you can try adding a stand to ventilate it or run a cooling system test
http://www.ehow.com/how_5976252_test-fan...
Add a comment
http://www.newsandroid.info/2017/03/12/h...
Add a comment
Add your answer
Bianka Castaneda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 27
All Time: 6,641
