The Huawei P8 Lite (Model: ALE-L21) announced April 2015, shows beauty in simplicity. Its professional cameras enable you to take natural and sharp pictures even in the darkest environment. The beauty mode highlights the best features of the owner in every selfie.
Why my phone doesnt charge?
my phone is not charging even if its connected to charger. at first there was this weird led lights blinking then after few moments it stays at 0% not even charging. I tried different charger but still not charging. My charger is working. Help please
Score 21
11 Comments
Sir I am also having the same problem that my mobile p8 lite doesn't charge , when I connect the charger .. the battery percentage does not increases, it stays the same .. Sir please guide me the suitable solution ... waiting for your reply ....
by
hello iam using huawei p8 lite my problem is that when i connect my mobile with my laptop my mobile shows the charging but not save how to fix it .
thanks
by
Huawei p8 lite not charging even after replacing the charging port,
What else can l do to fix it please
by
i have huawei gr3 2017 known as huawei p8 lite 2017 or huawei honor 8 lite
with a battery problem
but after changing it does'nt increase in charging porectage
the screen is on when i put the charger
but there is no ''electrecity logo " in the battery poucentage
by
use a good 3.0 mah charger or 2.5 mah charger. it works sum time 2mah or 1 mah charger was drain the battery's be cues of low amp and charging I-C temperate get hi and drain the mobile battery.
by
Show 6 more comments
Add a comment
Chosen Solution
Hi,
Blinking red light indicates low battery (when phone is not connected to charge). It should turn to a steady red light when charging. Is it steady when you have connected the charger?
If not, you probably have a faulty battery or faulty charging circuit in the phone.
If so, how long have you left it on charge? Leave it on charge for 1-2 hours and see if it starts to charge.
(I suggest this because I had a android phone with a completely flat battery which initially did not respond to the charger, so with nothing to lose I left it on charge, after 1.5hrs it suddenly kicked into life and started charging and subsequently took another 3 hours to fully charge - and has been good for over 12 months now charging normally)
If it does not respond at all after you have tried the above you probably have a faulty battery or faulty charging circuit in the phone. Check your warranty details and if still valid contact the maker.
Score 14
3 Comments:
This was helpful because i had the same problem
by
help ful idk
by
My phone not used to get charged n used to show red light instead. Also its back button not worked. I put my phone in the freezer for 2 hours n repeated this action 3 times. After a month the charging came to be normal. Also the back button not worked n I found out that it was because of the water which had entered the screen of the phone. I installed back button from play store n after few days the phones back button started working itself. Now is my phone working perfectly n it does't have any defect. But I'm sure that the back button will be not functioning if the rain hit my phone screen. I have to save it from water because it takes almost a week untill its back button gets normal. My phone is 4 yrs old n is like a friend to me. Not wanna change it.
by
Add a comment
Basically I have found the best solution to such a problem, all you have do is unplug from charge, turn on the phone, when the Huawei logo shows up on boot, plug the charger in on that stage, once turned on it mostly starts charging normally.
If unsuccessful, redo the same steps after the phone shuts down automatically. Once you get into the timing, it will work every time(as it has with mine). Even tho it is becoming an unecessary hassle.
This method works, I certify it with 100%
Score 10
7 Comments:
I am not sure why this works, but it does. My phone now is a couple of years old and has only just started doing this...I guess time for a new phone
by
Hi @Alun Evans,
It may be time for a new battery. Even rechargeable batteries have a life span. If you feel so inclined here is a link that shows how to replace the battery. It also has details of which battery to buy. This should also be printed on the battery.
All this is of course if you have a Huawei P8 Lite!
https://www.youtube.com/watch?v=mSTMIQ-w...
by
when I plug my huawei p8 lite for charge, it show me its charging, but slowly it starts to loose charge. what should I do??
by
Hi @ imtiyaz nabil,
Have you tried a different compatible charger?
Are you charging it and using it at the same time when this happens? If so try fully charging it with the phone off and then see how long the battery lasts.
What do you mean that it starts to lose its' charge? Do you mean that this happens when it is charging?
How old is the phone?
Even rechargeable batteries have a life span. if it is 2 years or more then perhaps you should consider getting a new battery installed.
by
Mine doesn't stay long if I charge it during the night the next day it first stay upto 2 hours what can be the problem? This is the third day using it it's brand new Huawei p8
by
Show 2 more comments
Add a comment
Hi folks,
I had the same “blinking red light during charging” symptoms on my Huawei P8 Lite with a completely flat (0%) battery. I guess this happens because Android requires a minimum level of power (2-4%, below which the phone automatically turns off) in order to control the charging process. What I’ve tried and helped was leaving the phone on charger for cca. 10 mins and after that I performed hard reset (pressing and holding Volume UP + Power keys simultaneously - the method may vary for other phones), just like when you want to wipe cache data. And voila, the phone started to boot and charge normally.
Score 1
1 Comment:
Brilliant I bought an huawei phone from a repair shop!! after i jumped in a hottub pissedup and forgetting my phone was in my pocket, I tried to have it fixed but it was unfixable!! So I bought another streight there and then, got it home and it wouldn't charge. Tried everything and the hard reset was the last thing I tried and it worked I had a feeling it was because the phone was in there for a few months and needed a good kick to start the charging process,.
by
Add a comment
Unplug the charger 'cube' from the receptacle and plug it back in to a known good outlet. Simple as that (this is what worked for me). Went from not charging and displaying a low battery symbol on the display when I pressed the on button to charging as soon as I plugged the 'brick' back in. East fix!
Add a comment
try a charger with a lower ampier output rating. this will result in a slow charge.
Add a comment
I find the real problem. And I fix it too. It's was the cable inside the phone. Was not insert properly. Me sooooo happy I find it and fix it!
1 Comment:
Add a comment
I had the Same problem. the problem was on the usb port of the phone’s board. broken pins and port. check the usb port of the phone.
Add a comment
My phone has found a charging problem. From a week now but 2 times it was charged when I froze the phone in could n then put it in charge. Plz freez it for 15-30 min not more. But now it gets charge very slowly n consumes charge when I use it while charging. But I know the phone is used almost 4 yrs now so I ordered a budget phone 'd come soon. Still I won't through it away but watch utube instead of using the new phone. Hope it'll help somehow…
Add a comment
I turn off my Huawei and keep it,after a few months ago,when I turn on ,it won't turn on. when plug in charger,red light flashing to fast than slow,but half day I keep in charger,also same thing the red light flashing
1 Comment:
My phone comes on but does not want to work further please help me
by
Add a comment
Add your answer
dennisloty will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 48
All Time: 165,586
