Repair and troubleshooting guides for the DeWalt DW106, a discontinued 3/8" variable speed reversing (VSR) drill with a keyless chuck.
Dropped Drill no response from trigger.
After 8 years of light use I dropped my Dewalt DW106 3/8 in VSR drill. 8 feet to a wooden deck. Since then it is dead. Opening it I see no loose connections. The motor turns freely by hand. The power cord is not frayed at any point. There is no smell or visible evidence of an electrical short inside the plastic shell. Have you any idea what part would be most likely to fail as the result of such a short drop?
1 Comment
Tried bypassing the switch to see if it will run without it?
by
Add a comment
Chosen Solution
Hy
Maybe, like odlturkey03 wrote, the Power Switch itself ist damaged.
Try tu bypass the switch and see if it works.
Score 1
Add a comment
control all the wire connectors start from powercable > (supression coils) carbon brushes and their springs) the switch + (L+R ) and the electric field .
Add a comment
Add your answer
supthehoop will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,031
