The Keurig Mini B-31 is a compact single cup hot beverage brewer that uses Keurig's K-cup dispensing system.
Keurig Leaking from the bottom
Please tell me why my keurig is leaking everywhere when the coffee pours out from the bottom of the machine ?
Score 6
1 Comment
my k155 is leaking because the tee fitting is broken inside . Is there a place I can buy these fittings?
by
Add a comment
Most Helpful Answer
I don't know why Keurig is so popular when I read there are so many people having various problems. I too have a mini-plus one cup unit that leaks all over the counter from the bottom area. I have tried a couple of fix its for this.
Around the top puncture needle is a rubber gasket seal that can foul up with coffee grounds that prevent it from sealing tightly against the coffee pack. Remove the gasket by pulling gently down on it and clean it. Don't drop it down the sink. Reinstall the gasket and give the maker another try.
The second fix I did was to clean the upper needle by using a small paperclip. Open the paperclip on one wire and gently press it into the three needle openings to clean out any old coffee grounds. Gently doing this will prevent damage to the inside attached water tube. This seems to eliminate the water leak for a period of time. I'm not sure how exactly this resolves the leaking at the bottom but it does. My understanding is the discharge tube backs up because of these conditions and runs out an overflow tube located near the bottom of the unit.
Both these fixes may have to be repeated frequently if the leaking reoccurs.
Score 2
Add a comment
My brewer dripped a couple of "tear drops" and stopped. I then put a cup of white vinegar in the reservoir and ran the machine. During the first brew the drip started to open up but it then began to leak from the bottom. I unplugged the machine, turned it upright over the sink to drain any left over water and vinegar. I then plugged it back in and ran two more cups of white vinegar through it followed with two brews of fresh water to rinse. The machine is now dispensing coffee at full force and it is not leaking.
PS: I did check the puncture needle first and that was clean and the rubber gasket was in good shape.
1 Comment:
Thank you for this solution it was exactly what I needed to do. Almost threw out a perfectly good machine thinking it was broken. I will add I did at least 5 -10 times of just running fresh water through it and got a lot of scale buildup out each time til I got clear water finally.
Jenny
by
Add a comment
Roland,
We did the same thing as Jenny and now it’s working well again.
Thank you very much,
Karen
Add a comment
1 Comment:
by
Add a comment
Mine is brand new, only used twice. It dribbles a tiny bit then shuts off. When I removed my mug I noticed the drip tray was full.
Add a comment
Add your answer
Maria Robertson will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 98
All Time: 22,782
