Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Fluttering lcd, sometimes an issue
So, recently, I've been noticing this issue, and it's very recent for me. Sometimes when I install a display assembly, I get fluttering lines, on the lcd. This isn't the same as when you use cheap parts, and you get those white lines. It's almost a strobing/blinking light. All the colors of the lcd picture are there. But they're doing the strobe effect. It's so weird, and I'm getting really good parts. So, I'm wondering if it's something I'm doing? Could it be my magnetic mat? Which Mav ruled out, in a different thread. Anything? Anybody? Oh, I've been getting this with iPhone 5S and iPhone 6
Score 2
Add a comment
1 Answer
Chosen Solution
I have seen this same issue when the LCD Assembly is replaced while the device is still powered on. Make sure you are disconnecting power before you conduct a screen replacement. Also, if your cables aren't connected correctly and you power on the screen it can cause this issue. Hope this helps! Keep us posted!
2 Comments:
I could see the connections not being properly seated, as the result. Thanks!
by
Flickering like that is usually a hardware issue, not software. It’s often caused by a loose connector, damaged flex cable, or the screen starting to fail.
You can try reseating the connector, but most of the time it ends up needing a screen replacement.
If you’re checking parts, you can look here: https://www.kiqparts.com/apple/iphone.ht...
by
Add a comment
Add your answer
iMedic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 359
