Find repair information on the second generation Toyota Tacoma. For model years 2005-2015. The second generation marked a change from a compact pickup truck to a mid-size.
How to change running light bulbs
Change burned light bulb. How to access old bulb to put in new.
Score 1
Add a comment
1 Answer
Are you referring to the amber turn signal bulb or the small bulb in the corner of the headlight? If so both of those bulbs can be easily accessed if you open the hood and reach around the backside of the headlight. There you can twist the socket to the right and pull the bulb out and replace them without removing the headlight entirely.
Turn Signal/Running Light Bulb Type: 4157NA
Small Side Marker Bulb Type: T10
1 Comment:
You can pry the plug off easily using a screwdriver between it and the housing. The bulb holder is a different story in it can be just a hard to turn object without a size a socket can cover. Careful with pliers to not break the plastic.
by
Add a comment
Add your answer
Tim Blackwood will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 58
All Time: 5,096
