Repair and disassembly guides and support for dish washing appliances.
lights flashing nothing wprks
Our whirlpool quiet partner ii dishwashers HEATED WASH, NORMAL, AND CANCEL lights were flashing when we got up this morning. Worked fine yesterday. Tried going through the reset cyle and umpluggong it and going back through reset. At a loss for what to try next any advice?
Score 3
1 Comment
My whirlpool 2011 has cancel light flashing
by
Add a comment
Chosen Solution
duane, try to reset your dishwasher first. To reset it, you will have to have the door open. It can not be latched. Press "Heated Dry," "Normal," "Heated Dry," "Normal" within three seconds of the first pressed button. Now close the door, this should reset your dishwasher. For some of the newer dishwasher, those that do not have dedicated 'heat dry' and 'normal' buttons, you push any 3 buttons in the following sequence: 1-2-3-1-2-3-1-2-3, with no more than a second between each button push. That will put the dishwasher in diagnostic mode. Let us know what you get and what exact model your DW is.
Score 2
1 Comment:
This worked for my Whirlpool dishwasher after I had tried everything for two days! Thank you.
by
Add a comment
Afternoon all, I have trying that exact solution for the same problem for the same dishwasher model type.
The "Heater Dry" lights up, but not the "Normal". Other lights that show up are "Pots/Pan", "Rinse","Sani-Rinse", "Heater Dry".
When I push the "Cancel/Drain", you can hear the motor runs.
Not sure if I will need to replace the panel, since the lights on "Normal", and "Light" have are not turning on at all
Add a comment
Add your answer
duane will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 85
All Time: 15,661
