VTech Baby’s Learning Laptop identified by model number 80-073800.
Why does the display not light up?
When the laptop is on, the sound plays correctly but the lights do not come on. Is there anything that can be done to fix this?
Score 1
1 Comment
I think you have a battery issue. I recently read about this kiddie laptop on http://firstbabylaptop.com/ and you need to have a full charged battery for sound/lights to work.
by
Add a comment
1 Answer
Chosen Solution
Although the device turns on and the sound works, the LEDs may be too dim to see. The issue may be caused by a low battery. If the problem exists after replacing the batteries, the LED may be out completely. Check out our troubleshooting guide under display issues to see if LED replacement is necessary.
Score 2
Add a comment
Add your answer
Christopher Kourmoulakis will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 32
All Time: 2,006
