A sturdy tablet designed by HP for business and government use.
Can I increase hard drive capacity?
Can I increase the storage capacity of the hard drive? The initial capacity seems too small for what I need and would like to increase it.
Score 1
1 Comment
The eidt bade work when concted to charching divice but not work when remove from it
by
Add a comment
Most Helpful Answer
The ElitePad comes with 2Gb of RAM and Hard drive sizes vary from 32/64 Gb. If more space is needed it is compatible to external hard drives that can be connected to USB ports on the docking stations or the detachable keyboard.
Score 1
Add a comment
You could use apps like Google Drive and Drop Box to store and access your information on a cloud system. You "expand" your memory storage and are able to access that info on other devices!
Score 1
Add a comment
I have a 128 GB microSD card in my Elitepad 900 G1, it seems to work OK
Russ
Score 1
Add a comment
The Elitepad has a microsd slot hidden under the cover symmetrical to the volume buttons. put a large microsd in there and you are away
Add a comment
No its built into the motherboard and you have a SD card slot that can go up to 64gb that's it.
Add a comment
Actually I used 128 MG cards n problem and reliably filled them up.
Add a comment
Add your answer
Kyle Marques will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 4,111
