Toyota's fifth generation Pickup
How to install oil pump
Need to know how to align triangles on oil pump..,
Score 1
Add a comment
Chosen Solution
Roberts right there are 25 teeth on the middle gear and 31 slots for it in the outer gear the arrows will change relative position when it runs. How it starts out shouldn't matter. All you need to be concerned about is that the arrows are on the same side
Score 3
1 Comment:
I see your name here a lot and old turkey
by
Add a comment
The triangles on the pump are not for alignment there to show which side is up. In other words make sure the triangles are all on the same side and you set. Hope this helps
Score 2
Add a comment
Add your answer
Joshua Mckinley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 2,699
