The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
Why is my touchscreen not working?
My screen is on but my touchscreen won't work.
Score 6
1 Comment
1. touch check
2. touch ic replace
by
Add a comment
Chosen Solution
Depending on the reason there are a couple of different solutions. If the screen is frozen, it will need to be rebooted. Either by holding the power button down for 10 seconds, or the power button and "volume down" button at the same time for 10 seconds. After it restarts, the touchscreen should be working. If it's still not working, the digitizer may need to be replaced. You can find the steps in more detail on the troubleshooting page
Score 8
2 Comments:
touch ic replace
by
Happens on mine after blue tooth mouse has been connected. OK after reboot
by
Add a comment
Try rebooting or if that doesn't work a reset Hold power button and volume down button together for 10 seconds. If these did not work there is a chance you damaged the digitizer if the tablet was droped or suffered a blow of some sort.
Score 3
1 Comment:
you going service senter
by
Add a comment
Mine did this I just slapped it till the digitizer went back and it worked and still does 2 yrs later
Score 1
Add a comment
tank you somuch i am happy
Add a comment
Add your answer
Jordan Soto will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 16,453
