The HP Pavilion dv9000 series was introduced in 2006.
Charger port is loose
I have a HP Pavilion dv9000 and my charger port is loose and you have to press the power cable firmly to make it charge, How would I go about fixing this, Thank you!
Score 1
1 Comment
Can I have my charger port replacement since the tip of it was not able to pick up charging afternoon it was broken
by
Add a comment
1 Answer
Chosen Solution
This is a replaceable power port which makes your job easy its not soldered to the motherboard. All you have to do is tear down the laptop till you get to the point were you can see the port and remove it. and replace with a new one which can be found on ebay
http://www.ebay.ca/sch/i.html?_odkw=HP+P...
there is a guide on ifixit though it is incomplete it should help with the disassemble
Disassembling HP Pavilion dv9000 Logic board
Hope this helps
Score 2
1 Comment:
you may want to check that the screw that holds it down hasn't just come loose
by
Add a comment
Add your answer
CodeBeasty will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 4,533
