12.1 Megapixel CMOS type sensor camera. has 14x optical zoom. Supports SD, SDHC and SDXC cards, as well as MultiMedia card and MultiMedia Card Plus and MMCplus cards. Uses a nonstandard battery.
I broke my LCD screen?
I dropped my camera. The LCD is cracked and i can't see anything, however it turns on and off. Do i need to replace the LCD with backlight? can i replace the LCD without backlight? thankx
Add a comment
1 Answer
Chosen Solution
I think you'll find the screen and backlight come as a unit. If you hang out on eBay, before long you should be able to get another camera of the same model and with a different fault such as a lens error quite cheaply. Swapping the LCDs should then be relatively simple.
Score 1
Add a comment
Add your answer
ohmygoodness23 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 589
