24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
Common Logic board burn spot?
Hello
My cinema display started smelling weird and then shut down. I opened it and found the problem to be a burned spot on the logic board. No problem I'll just replace the logic board and then I can use it again.
So I was browsing for a new board when I saw a dutch thread with someones logic board also burned. But the weird thing is that the burn is at the exact same place.
Does anyone have had a problem with a burned board?
Score 4
2 Comments:
Lukas Guy, it might help if you add some images to your question. That will allow everybody to see where the board gets damaged
by
Hi Lukas Guy, I have a Apple Cinema with probably the same issue. How did you replace this part? Where can i buy this part?
Gr. Vincent (from Holland as well)
by
Add a comment
1 Answer
Lukas Guy, that looks like the LED driver. It is most likely a "common" failure if you have a short within the backlight circuitry. Any short there would take out that driver. I would suspect the primary offender would be the LCD connector.
Add a comment
Add your answer
Lukas Guy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 2,793
