Up to 20% off select tools
Tickle Me Elmo is a children's toy from Tyco-Preschool, based on the character Elmo from the children's television show Sesame Street. It was introduced in the United States in 1996.
Why Elmo stop Vibrating?
Elmo stop vibrating, can I replace the vibrating part?
Add a comment
1 Answer
Chosen Solution
jeaddy4, yes you can, if you can find it. Check the weight in the vibration system and make sure that the gear is okay. Take a look on here
Score 1
3 Comments:
Yes! Your answer help me find and repair the problem. The small gear (about a quarter inch in size) that fits into the larger gear was broken. The small white gear that was attached to the motor. Thank you.
by Share
Good for the older Elmos. Is it the same for the later ones?
by Share
@jeaddy4 - Struggling to find the little gear. How did you find a replacement?
by Share
Add a comment
Add your answer
jeaddy4 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 39
All Time: 4,154
