The second generation PlayStation Vita, the PCH-2000 series, is commonly referred to as either the PS Vita Slim or the PS Vita 2000. Announced in Japan fall 2013, and released in North America in May 2014. It is rated as a hand held entertainment device. Supported by :: Wi‑Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Model number: PCH-2001.
Joystick want move foward
Can it be fixed without new parts
Score 3
Add a comment
1 Answer
It might be a connection problem. I had that happem when I spilt water on it. Even after it dried it was wierd. What I did was took off the back and where the side of the joy stick is I unscrewed the screw and carefully took it out. If it dosnt move there are clasps that should hold it in pop them gently back. You should see the cable that connects into the main system. You have to be gentle and unplug it and reply it. Taking it out is easy putting it in requires a bit of patience and gentle hands. Try to see if that worked before you close it up.
Add a comment
Add your answer
Wade laster will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,511
