Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
Where is the screen connector located?
Hello,
I recently replaced my Oneplus One battery, my phone now completely works but the screen does not, it is always eitheir OFF or only display black. I might have messed with the screen connector but I don't know wich one it is so if anyone could tell me so that I can reopen the phone in order to reconnect/clean the connector :)
Thank you !
Score 2
1 Comment:
Florent did you fix the screen issue? I had similar issues. Dead battery first so I opened the OPO and disconnected the battery connection and plugged it in again. Surprisingly this worked. But a few minutes later my screen went black ans sinc then it stayed black.. Everything works except that my screen is always black. If you can help me out please let me know!
luyten.mathieu@gmail.com
by
Add a comment
Florent did you fix the screen issue? I had similar issues. Dead battery first so I opened the OPO and disconnected the battery connection and plugged it in again. Surprisingly this worked. But a few minutes later my screen went black ans sinc then it stayed black.. Everything works except that my screen is always black. If you can help me out please let me know! luyten.mathieu@gmail.com
Add a comment
soft drop screen is on but hap tics touch will not respond. who fixes these? must be connection problem
Add a comment
Screen connection is on top by the camera. F.Y.I if you didn't touch the screen connection then it's not the issue..
Add a comment
Add your answer
Florent Noel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 42
All Time: 553
