The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
Adhesive will not stick
I just fixed a Sony Xperia Z and after a little while the adhesive does not want to hold the screen in some places. Do i need to buy a better adhesive?
Score 3
1 Comment
I have used kitchen silicone. I have changed this phone display 3 times works every time :)
by
Add a comment
Most Helpful Answer
This seems to be a big issue with S5's and Sony Experia's. Best thing to do is to make sure you thoroughly clean frame, apply a plastic adhesive activator and use high quality adhesive's. Also you need to check your frame/chassis for damage, separation, and or whether or not its bent. We've been looking for a supplier for Sony Experia OEM water proof adhesive. If anyone knows where to get it can you please let us know. Thanks
Score 1
Add a comment
heat it up with a hair dryer carefully, then put it on its back facing down, put a little weight on the top and leave to set. as mentioned above make sure the bezel is clean from the old adhesive, there is a glue that does help called B7000 we sell this on our site and its a great glue for this type of job, not corrosive like superglue and its flexible at the same time.
1 Comment:
Glue B7000 where can i find it, i can't find it on his site
by
Add a comment
Add your answer
heljar97 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 884
