Up to 20% off select tools
Sony Xperia J, is simply a smartphone that works on Android software.
Problem with network signal
I have a problem with my network signal.
I opened phone and found out that the connector from the second (lower) board has broke.
By the connector i mean the one that has a screw hole in it, its by the vibration mechanism.
picture of the board
So i would like to know if that's why i don't get network signal, or should i investigate more?
Score 2
Add a comment
Do you mean this connector?
If this connector is broken you may have a problem with network signal strength. You need to solder it or replace this subboard. A good idea is the replecement of the rf cable (a black cable connected to this subboard).
Add a comment
The problem that you state.have different problem with mine situation
Add a comment
It seems that the RF connector is damaged...kindly look at the condition maybe that is the reason and you need to replace.
Add a comment
Add your answer
filerzr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 30
All Time: 3,205
