Vintage style turntable with modern additions like headphone, CD, and MP3 support.
How do you replace Crosley CR42 volume switch?
How do you replace volumn switch
1 Comment
Do these people ever answer questions on here Lordy
by
Add a comment
Most Helpful Answer
If his volume control/ switch is like mine, the power goes off when the volume is turned all the way down. It clearly is the switch. (I am a very experienced qualified Electrical Engineer, who put myself through college doing repairs after I 1st got my Associates degree in Electronics. Also the unit I am repairing has the right channel out from the CD player. I have put a oscilloscope on it, and even with the right channel disconnected from the CD player, only the left channel has an output. The volume from the CD player is also very low as compared to the other inputs to the amplifier. I am assuming I need the circuit board that sits atop the CD player. The chip that delivers the audio out from this circuit board would be a difficult one to solder in, because of the very fine pin pitch. I forgot to write down the IC # before reassembling the unit.
As far as getting the switch, you will need to remove it, record the manufacturer, and the part number, and search DigiKey for it, also If they don’t have it try Mouser, & Allied electronics. Lastly look to see if the manufacturer has a list of people who carry their parts.
A SERVICE MANUAL WOULD BE HELPFUL, DESPITE HAVING THE UNIT TROUBLESHOT ALREADY
Score 1
Add a comment
Crosley systems are not made to be serviced and access to the boards is extremely difficult. The power switch is a generic switch that should be available from a number of suppliers (Digikey, Mouser, etc.), but you must match the part from your device. If you can open up the unit and post a photo of the switch you would like to replace, I can point you to a few options.
Also, what makes you think that this switch requires replacement?
Dan
Add a comment
Add your answer
aspenbooks will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 36
All Time: 689
