The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
com.nb.superuser motorrola droid razer
my motorolla droid razer is automaticallu connected with mobile data and wifi even both is off and says com.nb.superuser is stopped please fix it the problem
Score 3
Add a comment
1 Answer
If you want to shut off your mobile data you have to do this:
Swipe down from the top of the screen, select Settings, press Data usage and then flick the Mobile data switch from ON to OFF - this will completely turn off your mobile data connection. Note: you will still be able to connect to the internet and use apps as normal if you are connected to a Wi-Fi network.
If your phone is having error messages like that you have to reflash your SuperSU.zip file in your recovery.
Here's the link for the SuperSU.zip to flash in your recovery.
https://download.chainfire.eu/696/SuperS...
Add a comment
Add your answer
kinokiran18 will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 11
Past 30 Days: 21
All Time: 1,675
