Up to 20% off select tools
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
Heating and Switching Off
MY phone gets heated and Switched off continuously mostly during video calling.
Score -1
Add a comment
1 Answer
Most Helpful Answer
Video call required high level resources and at that time your phone preform it's maximum and cause to produce heat. if you are yous in poor coverage location producing heat can be higher than normal but restarting means there is something wrong in the system. if you feel abnormal heat during the long use you may have to start diagnostic in the motherboard otherwise replace the battery and see. most probably your fault can be solved
Score 1
Add a comment
Add your answer
sumit will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 274
