Repair guides and support for phones manufactured by Lenovo.
contact manager has stopped
Unfortunately contact manager has stopped why? Rectify?
Score 27
14 Comments
I have Lenovo A6000 which I bought in December, 2015. I am receiving an error message that the contacts manager is not responding. The phone then goes blank on the screen. Kindly advise.
by
Searching contacts & SMS problem continuous showing loading......... During using internet.
Thanks,
Manoj Kumar
Ghaziabad U.P.
by
yes i have also same problem
by
i am using lenovo k4 note. some of my saved contacts are not shown in contacts manager though i have saved them twice or thrice. sometimes it show them all and sometimes a particular contact is not shown even once and bcoz of which i am unable to make a call.. fed up with this prblm..
by
sir i am using lenovo k5 note. some of my saved contacts are not shown in contacts manager though i have saved them twice or thrice. sometimes it show them all and sometimes a particular contact is not shown even once and bcoz of which i am unable to make a call.. fed up with this prblm..
by
Show 9 more comments
Add a comment
Chosen Solution
Hi,
I had this problem with my A6000. The contact manager was going very slow and my phone would, at times, not wake up from the sleep mode. This used to happen even when I get incoming calls.
I realized that the problem was happening particularly when I was connected to the Net and was using Whatsapp. After lots of hair splitting and frustration, thought of deleting the cache and data of Whatsapp. This worked !!! Phone works perfectly now.
Varkey
Score 11
1 Comment:
Quite useful information thanks dear!!
by
Add a comment
hi,
go to App
All App
locate Contact storage
force stop
open the phone book
check the response by searching some names
Its working for me, but Lenovo needs this capsule thrice a day :)
Score 3
2 Comments:
sahi baat he aisa hi hota he
by
thanks for this info, i finally got my contact now. excellent solution
by
Add a comment
Hello Rajesh Rajan,
There are so many reason to occur the issue you mentioned
1) Virus/ malware infection
2) Contact database corrupted
3) Due to 3rd party application which share your address book such as Viber, line ets..
4) Sim card contact memory location having issue with data filed
5) recently you imported contact complicating or address book limit exceeded
Simply you can reset the device and most probably fault will be fixed but before reset the phone make sure all contact backup to the your google account.
Hope this answer help you!
Thanks
Score 2
2 Comments:
my lenovo s820 also like this.after i hard reset like youtube show,the result is same..what should i do??
by
you can solve the problem updating the firmware. or flashing the OS
by
Add a comment
Use true caller dailer download from play store.
Score 1
Add a comment
Hi everyone,
I purchased k4 note and in 10 days I started getting this error message 'contact manager not responding'. But I am not facing this issue for now and would like to share what I did and hope that those who are facing this problem might get a resolution.
I removed the mem card and switched on my cell and I realised that my contact manager started working fine.
I put the mem card in a card reader and attached it to my PC. I found a file named ' conatacts001' and I remembered that I had shifted my contacts to mem card to ensure I have all my contacts in K4.
However, I had also realised that I had 500 contacts in mem card n 500 in my normal contacts. So K4 took time to read 1000 contacts and that's why my contact manager did not respond.
I deleted contacts from my mem card and it's been more then 10 hrs now and I have not faced that issue.
So if someone wants to try this please go ahead and I hope it works for all those who are facing this problem :)
1 Comment:
My memory card was clean when I inserted. I used google contacts but switched to phone contacts only considering that it will load contact manager fast but it didn't.
by
Add a comment
S930
Install True Dialer, True Messenger and 360 security, removed unwanted apps after rooting.
Working fine from the last 10 days.
1 Comment:
I even tried factory reset two times, used Contacts+ & KingRoot app but still in vain. Using S650 since 1+ year but this issue still there :(
by
Add a comment
From any Home screen, tap Apps.
Tap Settings.
Scroll to ‘APPLICATIONS,’ then tap Application manager.
Swipe right to the ALL screen.
Scroll to and tap Contacts.
Tap Clear cache button.
Tap Clear data button, then OK.
Add a comment
One trick is worked for me guys!
Remove cash and data from WhatsApp and voila.
Later on you can add your number and all details to WhatsApp again without any problem
Add a comment
I'm using lenovo vibe x2 ........I got the same issue that, " contact manager has stopped unfortunately"...I got irritated lots of times ..when I want to make a call...one day I fedup with the this error dialog box and made factory reset to check for same issues will occure or not in future .....until now i didn't get any problem with contact manager issue ...in my case factory reset worked ....warning : before going to do factory reset back up Ur data........hope this may help...
Add a comment
hi guys, I think it has to do with whatsapp. I have had issues with whatsapp in the past, so i refused to update it
So when this issue of 'contact manager has stopped' started, i saw this article. I quickly cleared data and cache of whatsapp, then updated whatsapp to the latest version. When I started the application, it asked for my phone number (normal setup) and verified it, then asked me to select to restore backups of the chats. I skipped the restore (this is important).
I have whatsapp but all my chats are gone. So memory is free. And contact manager works fine. By the way, my phone is rooted.
I suggest you uninstall whatsapp completely. Then re-install and do not restore any backups, just use it fresh. And clear data of other apps too like, play store, browser, etc.
Hope this helps
Add a comment
Bought new Lenovo A8 50. Edit option throws error " Unfortunately, contacts has stopped".
Tried clearing cache and reboot for many apps. Finally worked when I cleared the cache of contact storage and WhatsApp and force stop of contact storage
Add a comment
my lenovo phab 2 plus unfortunately telephone has stopped how to fix this
1 Comment:
what finally worked for me, was to uninstall whatsapp and clear cache/data, then re-install. I also started having the same issue when I recently updated whatsapp, and i quickly cleared cache, and the problem stopped.
I hope this helps.
by
Add a comment
how to fix it .my lenovo a916
Add a comment
I have the same problem with my Lenovo Tab2 A7. This comes up with a box where I have to click OK but as soon as I click, the box comes up again. Some of the answers say do this and do that but I can’t go any further past this box. Any ideas?
Add a comment
Add your answer
Rajesh Rajan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 18
All Time: 68,506
