Also known as Sony Xperia C6503, Sony Xperia C6502, Sony Xperia C6506, Sony Xperia ZL LTE, Sony Xperia ZL HSPA+ Released as Sony Xperia ZQ in Brazil Launch Date: January 2013
Phone works only on charging
Checked with battery and charging port ...still phone does not work ....works only when in charge else gets switched off
Score 3
Add a comment
change the battery but test it on your phone before maybe its a software problem !!
Add a comment
the batteries in these phones have a safety circuit built into them the ZL had a bad production run at one point and this safety circuit goes faulty for no reason and when you unplug the phone from the charger it trips the circuit and the phone shuts off. the battery needs to be replaced and since its a non removable battery(internal) its not exactly simple to replace unless you have experience in mobile phone repair.
Add a comment
Add your answer
maryshalini02 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,223
