Up to 20% off select tools
The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
Can my cpu be fixed
a capacitor fell off the cpu. can it be resodered?
Score -1
Add a comment
1 Answer
Yes it can. You might want to check the value of the capacitor to be sure it is still good. I have had one drop off due to poor soldering. I was able to resolder it using a 25 watt soldering iron with a very small tip. I had to use regular 60/40 solder that melts at 360 degrees F. It worked. Just don't over heat the solder joint.
Add a comment
Add your answer
madruler will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 17
All Time: 255
