Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
Why does the engine warning light remain on
The engine warning light remains on.
Score 1
1 Comment
it's the egr valve most likely. common ford problem
by
Add a comment
Chosen Solution
The engine light is telling you theres something wrong with your car and that you need to give it some attention . You can start by getting a OBDll reader and getting the code to tell you just what you need to fix. Once you have the code and have fixed the problem you can delete the code and the light will be out
Score 1
Add a comment
You do not give us a lot to go on. I suggest that you get the OBD scanned at places like Autozone or others and see what code it returns. there are hundreds of reasons why the light could be on.
Add a comment
Replace the engine if it's bad
Add a comment
Add your answer
dbryantnc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 879
