Bicycles from the manufacturer Jamis.
Why is my Jamis Road Bike skipping
My bike is starting to skip. What can l do to fix it?
Score -1
Add a comment
1 Answer
Most Helpful Answer
I assume you're talking about the drivetrain skipping.
If the chain is jumping past certain cogs in the cassette (or sprockets in the freewheel) this could be an indication that your derailleur hanger is out of alignment. Park makes a special tool for this, though it is generally too expensive to buy for casual use. This adjustment is easily made by shops, and generally inexpensive to perform.
If the chain is slipping while in a certain gear, it is likely due to a worn chain, sprocket or chainring -- though occasionally proper lubrication of the chain will fix it.
Score 1
Add a comment
Add your answer
carriereimer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 342
