Up to 20% off select tools
The Garmin Nuvi 65LM GPS was released in 2014. This device features a 6" dual-orientation display, preloaded maps with free lifetime updates, and millions of searchable points of interest.
Battery vs. Charger Issues
My Garmin Nuvi 65LM won't turn on and I do not know whether it is the charger or the battery at fault. Is there any way of finding out without having to buy replacements for both?
Score 1
Add a comment
Most Helpful Answer
You can use a standard MicroUSB phone charger to see if the Garmin charges.
Score 2
Add a comment
Most chargers will have a light to show whether it is charging or not. If you are using a non-Garmin produced charger, an error message could appear stating that charger will not work.
Score 1
1 Comment:
Correct on all counts. However even though Genuine Garmin as came with device, red light appears ok but device does not boot from off setting when plugged-in and is thus is not charging. When device is plugged in from on setting it either turns off altogether or indicates battery not charging??? Friggin' Nuts..
by Share
Add a comment
Add your answer
Patrick Beahan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 1,019
