Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Where is located the screen backlight fuse?
After a liquid spill, I've cleaned the motherboard and connexions. Everything worked fine for some time but the screen started to blink and went dark a few times until it got dark permanently.
Anyone can point me where the screen backlight fuse is located in the 13" retina mid 2014 model?
Score 3
Add a comment
Chosen Solution
Roy Lopez, that would be F7700 which is a 3 A 32 V fuse in a 0603 package. This "screen started to blink and went dark a few times until it got dark permanently." does not sound like the fuse. You do want to check a bit more. Of course, check the fuse first.
Score 6
Add a comment
Pin 1 of LCD connector is probably &&^&@@.
Add a comment
Add your answer
Roy Lopez will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 12
All Time: 5,436
