Originally released in 2006, the NeatDesk is a desktop document scanner with ADF and full-duplex features. The early revision has model number "ADF-070108" and the newer revision is model "ND-1000."
How do I re-install a spring
There are two springs under the cover. One on the left one on the right. One came out. I have it. How do I get it back in? I didn't try to fix it. I was afraid to make it worse.
Score 3
2 Comments
what if the lever broke and there is no bottom
by
No helpful for the NeatD 1000. I do not see where to insert the level / spring. How about a drawing or a picture ?
by
Add a comment
1 Answer
Most Helpful Answer
when you open the lid, the back of the front lid there are 2 spring loaded levers on each side. put the bottom in then the spring then push the top in place
Chad
Score 1
5 Comments:
my lever is broke and there is no bottom portion to put in first. Ideas for replacing
by
We need a drawing or picture as I do not see where the level and spring 'go in'.
by
My spring is missing, where can I get a replacement?
by
Tried that and lost spring in machine. Now what do i do?
by
where can i take my neat machine for repairs? 5/1/2017
by
Add a comment
Add your answer
Nita will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 25
All Time: 1,078
