Released April, 2014. CPU - Quad-core 2.3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M colors, 1080 x 1920 pixels, 5.2 inches. Internal memory - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
Xperia Z2 Wont turn on
I recently replaced the LCD screen and after putting it back together it doesn't turn on when the battery is connected. When i disconnect the battery cable the screen lights up and the battery icon shows up. When i plug it back in the LED light flashes three times and nothing happens.
Score 10
Add a comment
Is this whilst plugged into a power source? Was the battery disconnected before the repair?
1 Comment:
Yes...and yes
by
Add a comment
Same problem. Didn't leave the battery connected when I did the job, no. Any solutions?
1 Comment:
Same Issue for me too, would be interested if anyone has a solution.
by
Add a comment
Also having this problem. Was all working fine until I disconnected the battery to replace it. :/ Now it will look like it is charging with the red LED, but not actually turn on :/
Add a comment
anyone found solution for this?
Add a comment
replace the battery work 100%
2 Comments:
I just replace my battery as still not working..Dont waste your money
by
I have the same problem, i was thinking of a battery reseat
by
Add a comment
I just replace my battery too. Not working. Dont waste your money. Buy new one.
Add a comment
http://forum.xda-developers.com/xperia-z...
Add a comment
The flex cable connector is not fully seated. It worked out.
Add a comment
Add your answer
Dylon Browne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 7,654
