Engine WIll not crank
Craftsman riding mower engine will not crank. Installed new battery and still will not crank.
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 47
All Time: 2,290
4 Comments
Is the mower turning over at all or is it just a dead mower?
by Nathan Wells
turning over backfires thru carb
by allenperkins364
adjusted air gap valves set gap on coil
by allenperkins364
after I changed my blades incorrectly the pgt9000 would not start with the switch. I can jump the solenoid and it will crank and run . I changed the switch and the solenoid , but still have to jump the solenoid. I think there is a relay that blows if the blades aren't on correctly, but I can't find it.
by meriview@aol.com
