Up to 20% off select tools
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
upgrade force touch trackpad
is it possible to upgrade my trackpad in retina macbook pro (2012) to the new force touch trackpad?
Score 5
Add a comment
Most Helpful Answer
Even if you could find the part, which will take months, the trackpad on MBPrs is mounted between the top case and some seriously glued on batteries. The probability of damaging the battery in the procedure coupled with the likely change in dimension of the force touch trackpad make this inadvisable to even attempt.
Score 3
Add a comment
The 2013 and 2014 have a different cable connector on the logic board from the 2015.
Score 2
Add a comment
Add your answer
andreas will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 32
All Time: 3,604
