Set-top boxes that run on the Android platform.
Tv box when plug power not start
Hello!
I have a Android tv box and it not working
when i plug the power it turns on for 0.5 sec blue led
and orange led
orange led is in the part of LAN
blue is the power light
Can anyone help me ?
Thank You !
Score 3
14 Comments
my android tv box no power how can I fix it
by
my android tv box want power up it r39 4k docooler box
by
I plug my power cord to the tv box and I can’t get the blue light to come on. I took it to work and the IT guys plugged it in and it works fine. I know I have a power supply.
by
I plug my T95m in to the power source and the blue light will not come on. I took it to the IT guys at work they hooked it up right off. Why doesn’t it work in my house.
by
I am having the same problem, cannot get the main page at all. When i brought it down to the dealer, it works fine, however, the same problem pops up again when i plug it at home. How to resolve this?
by
Show 9 more comments
Add a comment
Most Helpful Answer
you need to reflash the firmware of your box
pin the box probably from the av port with a pin and at the same time plug the power add the firmware on an sd card and select apply update from external.
enjoy!!
Score 2
9 Comments:
Sometimes its not enough. You may need to do a mask rom, by shorting two pins of a particular chip nside hardware. There are various free software to do a reset and load a rom, depending on the kind of processor you have.
Often the problem could also be the power supply.
by
Yes,
My Android TV box got corrupted while I was trying to flash a custom firmware.
Now I am unable to get any light on while powering it up.
I have an amlogic 905X processor, can you please suggest some way to power up the Mini II m8s android TV box?
docgaurav-at-gmail.com
by
I have a W95 Android box that will not turn on when I plug the power cable into it!
Why is this??
by
You have a bricked box and the only way to possibly fix it is to take the back off and find a working tone key and at the same time use a computer program to push the original firmware into it.
by
my r-box pro not staying on when power up?
by
Show 4 more comments
Add a comment
#1 I would first check the power supply, with a voltmeter. See if it is putting out the correct power. those numbers on on the output listing on the power supply.
#2 try a different power supply ( but the same details like 12 volt 1 amp example only)
#3 reset the unit. lots of units have a small port that you can use a paperclip and softly push till you feel reset button engage. Normally hold power button in for 10 seconds what supplying power.
#4 contact support . Most vendors provide DOA (dead on arrival) warranties, and know their product well.
good luck !
1 Comment:
On live tv, most 90% just read under maintenance... all the time. also says low memory...Live tv??? No instructions to correct this problem.
by
Add a comment
I have a T95 android tv box. On the first day of installation it came up and work perfectly. After doing some stuffs same day, I put it off via the remote control. 30 minutes later try to put it ON but it refuse to come up.
Add a comment
Is pause not working
Add a comment
Add your answer
Serafin will be eternally grateful.
Past 24 Hours: 14
Past 7 Days: 30
Past 30 Days: 62
All Time: 66,099
