Up to 20% off select tools
How do I replace my track pad button?
Mouse pad Button is stuck and I need a replacement, donor or otherwise. Please advise.
Score 3
Add a comment
Chosen Solution
A less expensive answer if you want to go that way would be to simply use an external USB mouse. If the button is stuck in the on position you may need to disconnect the trackpad cable to operate properly. Ralph
Score 2
Add a comment
I am using a new answer because I can't leave a URL in comment.
If you do want to replace the upper case here is a source. Ralph
http://cgi.ebay.com/Apple-PowerBook-G4-1...
Score 2
2 Comments:
For the record I tried three times to leave this as a comment but the program would not allow me to leave a "clickable" url. Ralph
by Share
So it isn't just me! If it happens to everyone I'll mention it on the uservoice
by Share
Add a comment
You would need to replace the upper case.
Score 1
Add a comment
Add your answer
Jackson Carrie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 3,548
