Use this repair guide to fix faulty parts in the Fujifilm FinePix S2980.
Why is my camera not turing on?
I keep using the power switch and the camera won't turn on. The screen is black and not making any sounds, what should I do?
Score 6
Add a comment
Most Helpful Answer
Hi John,
There are a couple things that might be wrong. The first thing that I suggest doing is replacing the batteries. If you do that and the camera still does not turn on, you may have to replace the power switch. Check here for more information.
Hope this helps!
Score 1
Add a comment
The lense won't extend. And tells me turn back on.
Add a comment
I had a battery leak in the battery compartment how can i repair my s2500hd camera?
Add a comment
Add your answer
John Kemmitt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 39
All Time: 2,285
