The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
USB 3.0 replacement on the left side
OK i was using it in class and stuffed it in my bag to move classes and the flash drive took out the USB inter face on the laptop how can i replace the USB port on the left side of the laptop
Score 1
Add a comment
1 Answer
Chosen Solution
If you, or someone you know is good at soldering, you can get the USB interface port online. If not, I would take it to a professional.
Score 1
3 Comments:
thank you i think i might get it services also do you think that if i send it in to asus they can fix it or would it be cheaper to get it done local in baton rouge
by
I would get it done local, It's a pretty easy repair. If you send it to ASUS...You may be without a computer for a good while.
by
thank you im going to get it done local
by
Add a comment
Add your answer
Cory Pixley will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 18
All Time: 807
