Up to 20% off select tools
Xperia ZR is the waterproof phone from Sony that lets you film in Full HD underwater. Released in June 2013.
Jumper solution for backlight issue
Hi Could you please provide jumper solution for dim backlight problem in Sony Xperia ZR.
Thanks much,
Shyam.
Score 4
3 Comments
Shyam, why do you think there is a jumper solution? what is going on with your backlight and what have you tried to fix it?
by Share
Thanks for your reply. I had dropped my phone near water source and it broke the screen. I puchased a new screen and when connected everything was OK except the brightness which became very dim (approx 30% of the original light) I checked in the settings-> display-> Brightness was set to full and Adopt to lighting conditions was set to off. I had given this phone to a local repaired as Sony has stopped support for this phone. He tried cleaning the board with a PCB cleaner thinking of water damage but to no avail as it could not turn the brightness to maximum.Now I want to get maximum brightness even if it is permanent because I can barely anything at day time. Please let me know if you want to do any other test. (Also I don't have circuit diagram for Xperia ZR)
by Share
If anybody can help me with the schematic diagram of Sony Xperia ZR that would be highly appreciated. Thanks in advance.
by Share
Add a comment
1 Answer
Most Helpful Answer
sony c5502 light jumper
Update (07/27/2016)
Score 1
Add a comment
Add your answer
Shyam will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 4,798
