Up to 20% off select tools
Sixth generation of Apple’s wireless base station, released June 2013. The tower provides dual-band support wireless access and is Apple’s first router with 802.11ac technology.
Thermal pad replacement comments?
I took my AirPort Extreme apart to give it a clean because it was full of dust. I thought I would remove the heat sinks just for interests sake. When I removed the heat sink I noticed it had a thermal pad between the sink and the Broadcom router chip. I was a little disappointed this was not mentioned in any of the tear downs as I like to replace thermal pads when I pull things apart. I had to put it back together as was but I am looking to replace the thermal pad. Does anyone have any suggestions? Also any suggestions on pad thickness? I was thinking 3mm from memory. IT seemed like a fairly big gap from memory. Any comments greatly appreciated. Also from memory there was definitely only one thermal pad yes?
Add a comment
1 Answer
Chosen Solution
These might work for you:
https://www.ebay.com/i/302812527840?chn=...
maybe these
https://www.amazon.com/Fujipoly-Extreme-...
or maybe one of these:
https://www.amazon.com/s/?ie=UTF8&keywor...
Score 2
Add a comment
Add your answer
opinio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 549
