12.3 megapixel DX-format F-mount DSLR camera from Nikon.
interval shooting timer , not selectable in any menu
I used the IST, once before , when to used it again , but it is not an available option any more. it is gray and all the info that I can get is that it does not work with bracketing settings .. any ideas
thanks
FR
Add a comment
Most Helpful Answer
I had the same problem with interval not available. Took the 64G card out, 16G in. Interval available again.
Score 1
Add a comment
had the same issue.. didnt like my memory card.. I had used it week before.. then when I tried to turn on the camera it said the card was not formatted and I know there was data on it.. so now today I took the data off that card. put back in d5000 and it said it was not formatted .. I let it format it.. and now interval is off.. I threw in another SD card and its ok.. doesnt like this micro SD card now.. I have another one I have in there now.. but something is strange.. so try another SD card..
Add a comment
Got the same problem.
- Tried bracketing off
- Tried inserting the date and time again.
- Tried a full battery.
- Tried resetting the camera (hold i button + info button together for a couple of seconds).
- Tried all possible modes and settings.
Then I've read somewhere to somebody had issues due his 64gb card. Now I see Kevin above here say something similair. Back in the day the D5000 came out, 64gb cards were not that normal. So I might buy a cheap 8gb and see if that resolves the problem. If not, I'm out of options.
Add a comment
Hi. I removed the battery and inserted back in and ITS worked again.
Add a comment
Add your answer
Frank RUiz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 2,686
