The Skullcandy Air Raid is a wireless portable Bluetooth speaker released November 15th, 2013 which streams music from any Bluetooth-enabled device.
Why wont my device charge?
I have checked my wall outlet and it works perfectly fine with charging other plug-in devices, it just seems to be a problem with my Air Raid. What should I do?
Add a comment
Most Helpful Answer
If the outlet is working and your device is still not charging, you may have a bad USB port. If your device only charges when the plug is held at a certain angle, will not plug in all the way, or has visibly bent/broken pieces inside the charging port, you should replace the USB port. If you have left the Air Raid charging for a long time, but the battery dies quickly after unplugging it, you may need to replace the battery.
Score 1
2 Comments:
You should try going to Skullcandy Air Raid Troubleshooting for more troubleshooting help
by
Where do i purchase a new battery?
by
Add a comment
@Sasha Nevin, SAME!! IDK what to do about it, but it is really annoying. I've had to use earphones (the ones u stick in ur ear) and was trying to get away from those, however it just won't charge! I also tried charging it through my computer, therefore it still didn't charge
Add a comment
Add your answer
Sasha Nevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 5,339
