Up to 20% off select tools
The Xperia Z1 Compact is Sony's premium camera phone. It is similar to the Xperia Z1 model except smaller and less expensive. Its key feature is a 20.7 megapixel sensor. Upon release the available colors were white, black, pink, and lime. This device can be identified using the model number (D5503)
Is it possible replace the battery?
I'm going to buy a Z1 Compact but I have always used smartphone with a replaceable battery. When the battery will be useless, is it possible to change it in a Customer Assistant Shop? Or will I need to buy a new smartphone?
Thank you!
Score 8
Add a comment
Most Helpful Answer
Yes, it's possible. You can have a look at Sony Xperia Z1 Compact teardown in advance.
Score 6
1 Comment:
I have the same problem, my battery fully charged but once disconnected from mains, turns itself off. I backed up my phone to laptop and reset but now it just switches on/off/on/off. I do not know what teardown in advance? Please help! Thank you
by Share
Add a comment
My problem was when received call via facebook, my phone suddenly black out & automatically switch off. After that i try to switch it on back but unable to do so even my phone is fully charged. And when i connected my phone to the charger, it's shows nothing & unable to charge. Is it my battery problem? Thank you!
Add a comment
I wont to change batry my z1 mobile
1 Comment:
I wont to change batry my mobile
by Share
Add a comment
Add your answer
Clare will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 32
All Time: 40,928
