Up to 20% off select tools
Released in October 2011. GoPro's second generation outdoor camcorder used by professional athletes, sports enthusiasts, and core enthusiasts.
Internal microphone does not work.
Hello,
I hum Problem with My GoPro Hero 2 from When I bought . Her microphone worked BY 15 days, since audio capture only with external microphone.
I saw several reports it can be the external connector that does not turn over the internal microphone , it proceeds ?
Is there any chance of getting the microphone and not the connector ?
thank you ,
Melvin Aster
from Brazil
Score 1
Add a comment
Did you plugged external mic into your camera?
If yes - it is common problem in some versions of hero2.
You can change (upgrade or downgrade) firmware - there is no specified version that is works, you have to try.
Then you should do not connect any external microphone (because camera will lock again on external mic).
Some versions of hero2 works good on latest firmware (you can use external or internal mic), but some also locks at external mic.
No known workaround for this issue.
Update (10/27/2015)
Also it is possible that mic cable is broken - you can simply fix it as shown in this tutorial (speaker replacement), but by mistake someone called it speaker while it is internal mic :)
Also mic can be broken, so you need to buy new one.
Add a comment
here is a link to the hero2 mic:
http://www.ebay.com/itm/GoPro-HD-Hero-96...
Add a comment
Add your answer
Melvin Aster will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 45
All Time: 1,915
